I hadn't realised but my scale had been failing to update my Garmin Connect data since 1st Nov despite using it daily.
After some investigation and a full reset plus re-pairing it over ANT+ on Garmin Express it still fails to connect. I can see it is getting an IP address from my router, but it just seems to be stuck on the Spanner with the upper bar of the signal blinking away and eventually, a cross appears in the top right, so I assume it is the failing to call home?
There's no software updates on Express for it (it's running 2.7)
My Garmin Edge 1000 and vivoactive both sync OK with the servers over wifi (edge only) and express, so I can only assume there might be something wrong at the Garmin end for the scales?
Anyone else suffering no connection to the Garmin servers from their scales at this moment?
