Index not uploading because of unreliable NTP server
More often than not, my Index wasn't uploading any data when it should. The wifi icon blinked for a while, after which an X appeared in the upper right corner of the display.
Initially I though it wasn't connecting to my wifi network properly, but when I looked at the network traffic, the problem turned out to be something entirely different: the NTP server the Index is using, clock.garmin.com, isn't responding most of the time. This is what used to happen most of the time when I stepped on my Index:
67699 2016-02-11 08:38:10.026783 0.0.0.0 -> 255.255.255.255 DHCP 303 DHCP Request - Transaction ID 0xa90d3832
67700 2016-02-11 08:38:10.029093 10.0.7.254 -> 10.0.7.116 DHCP 342 DHCP ACK - Transaction ID 0xa90d3832
67701 2016-02-11 08:38:10.173502 GarminIn_41:c4:f0 -> Broadcast ARP 56 Who has 10.0.7.254? Tell 10.0.7.116
67703 2016-02-11 08:38:10.684652 10.0.7.116 -> 10.0.1.2 DNS 76 Standard query 0xa487 A clock.garmin.com
67704 2016-02-11 08:38:10.685102 10.0.1.2 -> 10.0.7.116 DNS 159 Standard query response 0xa487 A 204.77.162.174
67705 2016-02-11 08:38:10.730001 10.0.7.116 -> 204.77.162.174 NTP 90 NTP Version 4, client
67706 2016-02-11 08:38:11.038477 10.0.7.116 -> 204.77.162.174 NTP 90 NTP Version 4, client
67707 2016-02-11 08:38:11.343489 10.0.7.116 -> 204.77.162.174 NTP 90 NTP Version 4, client
67708 2016-02-11 08:38:11.653700 10.0.7.116 -> 204.77.162.174 NTP 90 NTP Version 4, client
67709 2016-02-11 08:38:11.975087 10.0.7.116 -> 204.77.162.174 NTP 90 NTP Version 4, client
67710 2016-02-11 08:38:12.288109 10.0.7.116 -> 204.77.162.174 NTP 90 NTP Version 4, client
After 6 unsuccessful NTP requests, the Index gives up and won't use the network for anything anymore. (when the server does respond, the Index will continue by sending requests to https://gold.garmin.com)
I worked around this problem by configuring my DNS server to return the address of a working NTP server instead of the actual address of clock.garmin.com, but it would be much better if Garmin would:
  • fix their server
  • update the Index firmware to request and use NTP servers given by the DHCP server
  • update the Index firmware to handle a failing NTP server more gracefully
  • Hi All,
    I know this is an old thread but my Index SS looks like it has the same issue, and I want to try and reconfigure this clock.garmin.com thing.
    I have a netgear Orbi system - can anyone help with what I need to change to make it work? I'm based in the UK so what NTP should I use, and how do I tell Orbi point to it instead of the Garmin one?
    (or, if you can't give me the specific details for Netgear, could you please tell me what to Google so I can figure it out?)
    Thanks!
    Luke
  • I use the parental controls on my TG585 router to redirect clock.garmin.com to gr.pool.ntp.org and my scale works perfectly ever since
    Can anyone tell me if the DD-WRT router firmware would allow me to redirect traffic being sent to clock.garmin.com to another NTP server. I'm pretty sure the firmware supports this but wanted to double check first.
    Thanks guys! This issue was driving me crazy.
    It took some effort to reconfigure my router, but redirecting 'clock.garmin.com' to the ip for 'pool.ntp.org' works like a charm. Finally getting those beautiful '>>>>>' every single time I use the scale.
    I can't believe Garmin still hasn't fixed the issue a year and a half after omolenkamp figured out what is causing the problem. A simple config change in their firmware should do the trick.
  • Hi All,
    We have seen that in multiple instances where there are upload issues after adding additional users, that problems were caused by these users not accepting consent for uploads. With the implementation of GDPR in the month of May, some of these reports are corresponding to Data Consent. This can be done by accepting consent from this link, or by having these users sign into their accounts within the GCM application. We are still investigating this but wanted to provide this potential fix/troubleshooting step in the meantime and get feedback from the group in regards to this working or not.
  • Hello,
    from Italy I can reach the Garmin NTP server (clock.garmin.com) but has a ping greater than 150ms! Very high!
    $ ping clock.garmin.com
    PING clock.garmin.com (204.77.162.174): 56 data bytes
    64 bytes from 204.77.162.174: icmp_seq=0 ttl=242 time=155.300 ms
    64 bytes from 204.77.162.174: icmp_seq=1 ttl=242 time=155.850 ms
    I modified the associated DNS zone in my network, forwarding the request to an Italian NTP server (20ms) and now everything is faster!
    PING clock.garmin.com (193.204.114.232): 56 data bytes
    64 bytes from 193.204.114.232: icmp_seq=0 ttl=53 time=28.420 ms
    64 bytes from 193.204.114.232: icmp_seq=1 ttl=53 time=28.367 ms
    The WiFi icon blinks much less!
    I hope this information can be useful!
    Andrea
    Hi All,
    This does not solve the WiFi issue which (at least that's one outcome of the user analysis discussed here) is related to the connection to the NTP server.
    In my case, I'm the only user. My ISP's router does not allow me to re-route clock.garmin.com to a different NTP.
    We need a solution via the Scale's firmware.
  • I don't run my own DNS but I have an always running windows machine in my network. I was able to spoof clock.garmin.com by installing the Acrylic dns proxy on that machine and configuring it as the primary DNS server in the network and configuring it so that clock.garmin.com is directed to another server. So far so good, I still get the X at the end of the weight data upload but data gets uploaded. This morning, before the change, it was not able to connect at all. Let's see if it keeps working in the next days.
  • Since last weekend my scale is running ok ... hopefully it stays so ...
