I've been using the FR935 with external heart rate monitors for over 3 years. I use the Polar H10 and the HRM-Dual. In the past, I've successfully used both in ANT+ and BT. I prefer the strap on the H10, but I like the battery life of the HRM-Dual. Previously, the only time I had issues with either of the monitor was if the battery was going low or the strap needs replacing. I run or ride about 6 days a week, so I change the straps about once a year.
Recently, over the past couple months, I've been having an issue that I just can't figure out. Both of the straps are relatively new and they both test very low resistance with my multimeter.
The issue is that WHEN RUNNING ONLY the HR on the H10 will start to falsely read around the hour mark. It will slowly fall from 130bpm down to 90bpm, even though I'm running at the same intensity. The HRM-Dual also acts up at around 1 hour into the run. However, The Dual may go way high(170bpm) or way low(90bpm). The weird thing is that I've had ZERO PROBLEMS WHEN USING EITHER UNITS WITH MY BIKE.The following are the actions I've tried:
- Clean the strap with soap ad water.
- Clean the unit with soap and water.
- Clean the contacts on the strap and the unit with an electronic control cleaner
- use the Garmin unit with the Polar strap and visa versa
- Use various shirt materials.
- rotate the strap around my body, both closer and further away from the watch.
- Ensure the watch is completely charged.
I seemed to have some success with cleaning the contacts and making sure the watch is fully charged, but today the HRM-DUAL went crazy during my run and it was fully charged and I meticulously cleaned the contacts on the strap and unit.
The only thing I could think of is that there is something wrong with wireless system on the watch or that the watch can't hold the minimum required voltage to ensure a solid connection. The issue with this theory is that I have zero problems when using either strap with my bike.
The watch really has had no major bangs or drops. The battery life on the watch isn't what it once was, but it's still multiple days.
Anyways, any ideas are welcome.
Wes
