I have the blue triangle after charging - have tried soft reset and all combinations of the hard reset i have read in this forum but blue triangle remains? Any ideas?
So you can't access the UI (menus/etc.) of watch at all? Turning it on and off by holding down LIGHT doesn't work?
Have you tried the following "master reset" procedure (you will lose data, so make sure all else has failed before trying this)?
EDIT: Sorry, my master reset procedure was incorrect (it varies by watch, and it's been a while since I had to use it). Refer to Elbo's comment instead.
Have you tried a master reset
It helped me in a situation where my watch could only display a blue triangle.
(note: you do loose all your settings, but if true up is enabled, you keep your scores for vo2max etc. But since your watch is unusable, loosig your settings isn’t the biggest problem)
