Add resistance on Connect manually for Indoor Cycling?
I use a peloton occasionally so I do an indoor cycle activity and then log into connect and add the distance, power, speed, etc. It has everything there but resistance. Is there a way to add this metric?
  • Currently the answer is no, although a workaround would be to include that data in the notes section of the activity. If that is a feature you would like to see added, Submitting an Idea to Garmin this link takes you to a page that allows you to submit the idea personally and if anyone else would like to see that feature added feel free to submit the feedback there for the quickest way to do submit the feed back. If this post get's some traction then I'll reach out individually and submit an internal case as well. If you would like the feature added, @me so that I'm notified and I will reach out directly.
