Weight information from a Withings scale is not syncing with Garmin since the woes
Weight information from a Withings scale is not syncing with Garmin since the woes.  I've checked all settings I can think of.
  • Have you tried removing and adding again  the sync connection between MyFitnessPal and Garmin Connect (I assume you sync using that route if you have a Withings scale)?
    After the Garmin outage, I missed 2-3 days worth of weight measurements (and added them by hand), but otherwise my Withings sync has worked without problems.
    • Thanks, all working well now after online chat sorted out my duplicate accounts
