Hi, My Garmin is not measuring distance when pool swimming. Is this a simple fault that can be fixed?
Eddie
Eddie
Hi thanks for your reply. Yes i was kicking off the walls.
If you make your activity public and post a link here then others might be able to diagnose what went wrong. You can also try the swimming watch tools to insert lengths in the FIT file.
Same problem. It stopped measuring distance a few days ago, I don't know what to do. Tried to restart and reset
Hard reset my friend. It worked for me as Garmin couldn’t help. Just reset your device, it’s a bit of inconvenience Nf you’ll need to set it up again but it will work
