Training load & training status sync with Garmin Connect
Why are'nt training load and status synced with Garmin Connect but only factor what the 935 itself measured?
If one does more than one activity and uses different measuring devices specialized for each then all of the accumulated data is poured into GC which shows the actual activity level while the 935 shows data that is, to say the least, irrelevant.
Personally I wear the 935 24/7, use it for running and take it off while I MTB where I use another device that sends its data to GC.
So...the 935 has my HRT, sleep, daytime movement and running...but not the MTB load factor.
Since the 935 syncs constantly with GC (app or WIFI) shouldn't it be quite easy to add this option?
In the setting add an option to sync all activity influence (not data but only influence which is already present in GC) or to caculate only regarding watch's activity data.
