I use a Stryd power meter with the latest firmware and have not seen any issues.
If you see a power meter connection icon that means that the Stryd is connected at system level, which it should not be.
The only way to get Stryd to record all their running metrics in the FIT file is by not using the native power connection. The Stryd datafield establishes its own connection and extracts and records all the data. If your Stryd is connected at system level the datafield will not have access to the ANT channel and will not be able to get the data.
You can still upload the data directly from the foot pod using the Stryd app on your phone, but you get much better results if you use the Stryd power datafield and link your Stryd account to Garmin Connect. Has the added advantage that it is almost instant and included GPS and HR data in the Stryd powercenter.
If you want to take it even further have a look at runalyze.com for very detailed power data analysis.
