LiveTrack affect on battery life
I tried a couple of windowsill battery tests and wanted to see if others are getting similar results.
First, with LiveTrack off, running mode, GPS connected outdoors, GLONASS disabled, Smart data recording, Smart Notifications disabled. I stopped it after 10 hrs 8 min, with 42% battery used. At that rate the total runtime would've been just over 24 hours, which is the factory rating.
Then another test with the same settings but LiveTrack turned on. It drained the battery completely and the watch shut off at 5 hrs 39 min. That's a pretty big drop.
I also did a race recently with LiveTrack turned on (and all other settings the same as above) and the watch died somewhere around 4 hours, but I wasn't as methodical with the testing. But in the neighborhood of my test above, anyway.
Anyone else have numbers to share?
Thanks,
Russell
