Display pace while using navigate course
Hi,
How can I display my pace while running and using the navigate course ? Love being able to focus on running and not carrying a map....but miss bot being able to monitor my pace during run.
If you add the map/navigation page to the run activity as a standard page, you can then modify it and add a data field (or two) that shows any of the standard data fields.
Sorry, I am rather new. How do I do that? I have a course saved that I plan to run tomorrow. While the map is displayed hike the watch is in navigate mode I would like to add pace.
Read the manual. The instructions are there and it is always worth trying to work things out yourself first.
If you cannot work it out:
Bring up the Run Press and hold Menu/Up (middle left) until you get Run Settings Press Start/Stop (top right) Scroll to Data Screens then press start/stop to select Scroll to Map Page. Press top right. Select number of fields. Choose layout, choose metric.
The other way is to enable the heading bug while navigating a course. That way you can use your normal data screens, but the heading bug (small red triangle) will show you which direction to follow the course.
