Current Compatible Devices:
- Forerunner 935
- fenix 5 series
- fenix Chronos
- Current Running Power
- Current Lap Running Power
- Last Lap Running Power
- Average Running Power
- Combo Running Power
Garmin and Stryd measure/estimate VO in a different way.
If Garmin has a 30% higher running power number with the HRM-Tri/Run because it's located at the torso as suggested, does the 30% "disappear" when using a standard chest strap and a Garmin RD pod?
Which doesn't permit a firm conclusion.
The only issue with having different methods is when you choose to compare them or, attempt to train using the different systems. As long as the system you use, be it Garmin or Stryd produces reliable numbers with good precision then it doesn't matter
having a power "standard" would just be easier for everyone
