Hi Guys, Sorry new to these forums. Recently bought a Fenix 5X and bought some marine charts to suit. My main application is not marine. I have uploaded the maps via Garmin Express however I am not able to view the marine map. I am not in the marine map area so do I need to be on the water in the map zone to view the map?
That's an app though?
Check out the CIQ field, DWMAP. It actually works pretty well. Not quite as convenient as the built in map, and won't show the detail level, but should accomplish what you are looking for.
Prior to getting the 935, I had a Forerunner 235 and used dwMap several times for navigation since the 235 didn't have that feature. The app works great and easily allowed switching between 4 fixed zoom levels. The limitation with the app is that routes loaded are simplified to 200 GPS points max due to memory constraints for the app (from what I remember when communicating with the developer). It's fine for short and simple routes. However, when the route gets too long and complex with too many turns, the route gets oversimplified when loaded to the watch. A series of turns may load as just a straight line for example. The routes I've loaded on the 935 (using routeCourse), so far, don't appear to have lost much, if any, detail when used in navigation. At this point, I do prefer the built-in navigaton over dwMap. Just have these annoyance like the lack of easy switching between zoom levels plus a few other things here and there.
Since the developer just replied to this post, can I ask is there any possibility to increase the GPS point limitation for the app for watches like the Forerunner 935 and Fenix 5 series since they have a higher memory constraint for Connect IQ apps then older watches. I wouldn't mine using dwMap on the 935 if not for the GPS point limitation of the routes compared to the built-in navigation.
