Strava multisport upload problem
Has anyone else had success uploading a multi-sport activity to Strava. I have my Garmin activities set to auto-upload to Strava, and that works fine all of the time for single activities. The problem arises, when I do an activity in multi sport mode and have it upload. I did a little sprint tri yesterday, and the data is all good on the Garmin side, but it only uploaded the run portion. I'm not sure why? I set up a custom activity for a bike/ run brick, and that does the same thing. I'm not sure that this is a problem with the watch necessarily, because everything else is fine. I don't remember this happening with my 735xt, so I'm going to use it to do a brick this week, and see what uploads. Just wondered if anyone else had seen this? It's a tri watch, so I'm assuming others have had these activities upload.
  • Welcome to the GARMIN support forum.
    You can't create a multisport activity on Strava so the autoupload tries it's best and you get a Run activity for the Run portion.
  • But Strava should split the multisport activity into each bit and so give you separate swim, bike and run activities.
    https://support.strava.com/hc/en-us/articles/216917817-Multisport-Files-and-Splitting-Activities says as much.
    Strava has to do it that way as it does not have a concept of a multisport activity and I have had to flag whole multisport activities uploaded as runs as then you get false running CRs recorded on a bike.
    Ask a stupid question but are you really sure you only have the run bit?
    Is it definitely the only one showing say at https://www.strava.com/athlete/calendar#Jun
    And is the activity time of the run correct? In other words, has it been able to at least parse that out of the multisport FIT file from your 935?
    This does sound like something you should at least raise a support call with Strava? I raised loads with them over the years and you always get a reply.
    Once logged in the direct URL is https://support.strava.com/hc/en-us/requests/new
  • Has anyone else had success uploading a multi-sport activity to Strava.
    Yes, a lot of times. No problem apart from getting multiple activities instead of one with sub activities. Doing a lot of brick training and this is annoying to see in Strava.
  • Not the same watch (920xt), but I am recently having a large amount of issues with multisport files uploading to strava.
    With triathlon multisport files, the swim will not upload. If I try to re-import the raw .fit file, strava says the swim segment is corrupt.
    I've separately recently done two aquathlons. On both occasions, strava has uploaded the run *three* times as different, non-duplicate activities (even though they are clearly duplicates as they're the same run!) and again, wont upload the swim.
    I can separately export the .tcx segments from Garmin Connect and then upload those manually, but even with those, strava isn't parsing the swim data correctly. On the web version, it correctly shows the right lap distance in both instances, but the headline distance for the swim is missing the final two lengths. See below for the same thing happening on both occasions:
    https://www.strava.com/activities/1036997001 (11 lengths of 91.5m [100yds] recorded in the lap info, but headline distance showing as only 823m)
    https://www.strava.com/activities/1053059820 (10 lengths of 50m recorded in the lap info, but headline distance showing as only 500m)
    This is very much a recent development. Triathlons and other multisport files uploaded fine last year, but this year I am having trouble almost every time.
    All is fine on Garmin Connect, and the auto-upload to training peaks is fine, so it's very much a strava issue.
