Live track is a problem
I have done the live track sessions several times.
It works fine to start the live track.
Finishing it is a bit more problematic. Most of the times the live track does not stop and the viewers link says this activity is not finished while it is. I have also added the extended visibility on it, but still the track does not show when the activity is finished.
Another thing is when you have started the Livetrack and stop it. Then start it again. Then the watch is NOT sending a link to the new activity at all.
This is happening every time.
You can try resetting the activity and start all over as many times as you like, but it does not start a new live track even if the activity is stopped.
The latter may be the reason to the problem as the live activity does not stop most of the times even if you stop the run, cycling or whatever you do.
I have tried this on both the 2.90 and beta 2.95.
Does anyone else have a similar problem with the live track?
