Assuming the 935 is identical to the Fenix 5 with regards the Run and Trail…
Doubt it is that simple. Anyway on most "trail" runs I have done your speed is vastly influenced by not just elevation but what you find under your feet and/or have to swerve round. In other words you…
Trail Run inhibits the calculation of VO2 Max and LTHR.
You’re not any ‘less fit’ because you’re VO2max estimate is based off a a combination of trail and road runs. It’s only a number. It does affect bragging rights though.
Given VO2Max feeds into so many of the other Firstbeat metrics, a reasonably accurate number is more than just bragging rights.
Given VO2Max feeds into so many of the other Firstbeat metrics, a reasonably accurate number is more than just bragging rights.Could you please point or link us to where either Firstbeat or Garmin has stated that any of the other Firstbeat metrics uses the derived value of the VO[SUB]2[/SUB]max estimate as an input variable? Remember, where there are two distinct functions [font="Book Antiqua"]f(x,y)[/font], and [font="Book Antiqua"]g(x,y,z)[/font], the assertion that function [font="Book Antiqua"]f[/font], “feeds into” function [font="Book Antiqua"]g[/font] would not be logically true, unless you can refactor function [font="Book Antiqua"]g[/font] to contain function [font="Book Antiqua"]f[/font] in its formulation.
