My Forerunner 735XT stopped showing GPS signal and doesn't record a track and doesn't show a map.
My Forerunner 735XT stopped showing GPS signal and doesn't record a track and doesn't show a map. I checked, GPS is on, but still the distance is not recorded. Please help! Marina 0412 308 310
  • Try rebooting the watch.
    0 Former Member over 5 years ago in reply to tmk2
    what precisely does it mean? to press both light and start buttons for 15 sec together?
    0 Former Member over 5 years ago in reply to Former Member
    I tried soft and hard rebooting, still GPS doesn't work and doesn't record the distance
  • By rebooting I meant powering off (by holding the light button and selecting "Power off") and then powering back on.
    After a hard reset the watch might need several minutes to get a GPS fix, so go outside, where you have unobstructed view of the sky, select a GPS-enabled activity, like for example outdoor run (but do not start it yet), and have some patience. If after several minutes you still don't get a GPS fix, then clearly there is something wrong with your watch, and you need to contact garmin support.
