Today I went to run a course I created myself, around the place where I work, for the second time.
The course is a 11.92 km loop so the end point is also the start point. Also the first ~100 meters of the course are also the last 100 meters.
To see the course follow https://connect.garmin.com/modern/course/13939195.
The first time I have been runnining this course I had no problems but this time after the first 100m I continued for ~50 in the wrong direction of the course. I noticed the mistake and turned around and followed the course in the correct direction. After turning around I noticed many beeps on my FR735XT, and then turn by turn navigation did not work anymore. The path I was running was drawn normally on the map (black where I have been running on green for the course), but turn by turn said next turn in 10.1 km, instead of a few hundred meters ! I continued running for ~2km but the turn by turn navigation did not reset to the correct position. The distance to the next turn got lower but it was definitely a turn close to the end of the course instead of the next one. This is the first bug.
I did not want to continue without turn by turn navigation even when the course was visible on the map, because I need the alerts for the next turn as I usually set the watch to display my heart rate. So I stopped the timer, pressed the up button to get ino the menu and stopped the course. Then I wanted to restart the course and to continue the activity. But it was not possible to get into the navigation menu. It is simply not available in this state!!! This is the second bug. I see no reason why it should not be possible to restart the same course or to switch course when pausing an activity! I had to completely stop the activity by saving it, then restart the course and restart the timer of a new activity. So now I have to activities where it should be just one (-> no statistics for this activity).
I hope the guys from Garmin read this here, because the last 2 times I reported bugs I did this online via the customer support and did not get even an reception acknowledgment.
