Thanks for your help. Here's the garmin connect link from the workout missing the second 400:
https://connect.garmin.com/modern/activity/1371740133
So the way this is set up, it's 100-200-300-400-500-400-300-200-100 with a fixed 30 second rest between each interval. I am pressing "lap" as I finish each interval (which I think I need to do, right? On my old Suunto it would just "know" that I stopped swimming). I don't press lap to start, I just go when the timer ends.
On the link above, when I hit lap at the finish of the second 400, it immediately took me to the 300, no rest. I hit pause (because I needed a little rest!) during that particular workout.
On the watch, under intervals, the second 400 does not show up, although it does show the total distance correctly at 2500 yards.
Thanks
Thanks for the link. One more question - when you say you hit "pause" after you unexpectedly found yourself in the 300, did you use the Lap button (like is typical for swimming), or did you use Stop-Resume?
To clarify the statement above, Pool Swim Workouts are very different from Run or Bike. You do need to press Lap when you get to the wall at the end of a set.
