My first tri - with indoor swim
Morning all,
I am doing my first ever sprint Tri a week Saturday.
From a quick look it appears as if the the Tri mode on the 735xt expects an outdoor swim. Is this correct and what's the best way to change that to an indoor swim?
cheers,
Greg
  • Setup a new Multisport profile (Settings, Activity Profiles, New) and specify the first leg as Pool Swim and the other two Bike and Run as normal.
    Alternatively you can edit the existing Triathlon profile and change the Open Water one to Pool Swim.
    I guess the choice is whether you think you want to have both options.
    Whatever you do, try a "pretend" triathlon activity (pretend to swim by moving your arms etc etc) to confirm it works as expected.
  • Thanks Tim,
    Option 2 seems the simplest and from a "sitting in my chair" test seems to work fine :)
    Thanks alot, thought it would be more complicated than that!!
    regards,
    Greg
