VO2MAX Widget?
Is there a why to get the VO2MAX in a widget? Can´t find any...
Thanks
  • In the main menu goto My Stats, VO2 Max
    But I think he is asking about a widget, which I interpret it as something that he can select using the up/down buttons from the main watch screen. If that is what is asking for, then I don't know of a default one unless someone has made a CIQ version.
  • But I think he is asking about a widget, which I interpret it as something that he can select using the up/down buttons from the main watch screen. If that is what is asking for, then I don't know of a default one unless someone has made a CIQ version.
    Yes a Widget so we don´t need to go into the menu etc... Like the other ones.
  • Ah OK - no then. Not sure that going into My Stats is any slower however!
  • … I don't know of a default one unless someone has made a CIQ version.
    I don't think that particular attribute in the user profile is available to Connect‑IQ apps anyway.
    https://developer.garmin.com/downloads/connect-iq/monkey-c/doc/Toybox/UserProfile/Profile.html
    Widgets are mainly intended to briefly display information that is subject to frequent and numerous changes while the user is wearing the watch outside of timed activities. VO2Max is not such a metric, so there is little real need to show in a widget in the loop for convenient, repeated access to the users several times a day, and there is Garmin-provided widget for it.
