Display Color on Garmin 735XT
When I first set up 735xt I set color as blue. For some reason color now changed to red and I cannot figure out how to change it back to blue. Any help appreciated.
  • When I first set up 735xt I set color as blue. For some reason color now changed to red and I cannot figure out how to change it back to blue. Any help appreciated.
    By default, the color used by the watch face is based on the color used by the current activity type. If you haven't tweaked the colors of the default activity profiles, red is for Run, light blue is for Pool Swim, and dark blue is for Open Water.
    To change the the activity profile...
    • Press Enter (top-right button) to exit the watch face
    • Press Up (middle-left button) to select an activity profile
    • Press Up (or down) to select the profile you want. The color of the profile is used to display the icon seen on the left.
    • Press Enter (top-right button) to activate the activity profile you've selected.
    • Press Back (bottom-right button) to return to the watch face
    Got it. Understand now it defaults to last activity used. Appreciate the insight. Will change all colors to the same. Thanks.
    Can you make your custom widget color show up on your last sport display screen?
    I could swear I changed the setting from custom to default on the last sport widget, but I cannot find how to switch it now. Am I crazy or can you do this?
    Thanks!
