Toggle between Course Map and Data Screen
Is there an easy way (e.g., one-button click while running) to toggle back and forth between the navigation/course map and the data screen with current run stats?
  • You can move one or the other so that they're adjacent, then use a single press of Up/Down to go back and forth. To do so, long press the Up button to access the menu, then go to Run Settings > Data Screens and press Start to edit (indicated by the pencil), then scroll down to Reorder and select it. You can also add the Map screen to your usual data screens so that you don't have to do this every time you load a course. (It can be useful even when you're not following a course to see where you're at in relation to where you've been.)
