How do I use a GPX map for my training plan workout runs as I'm unsure. I'm training for a half marathon on trail and want to also explore so I don't get bored.
Hi there! Once you are ready to run hit the top right button, and once you see run, press and hold the middle left button. You'll get Run Settings, Training, and below that Navigation. Hit your top right button, then select Courses, by hitting your top right button.
I can see how to do this if just doing a training run, but still unsure if it is possible when doing a workout from a Garmin training plan where the time and pace needs to be seen.
How do you loaded a map onto your fr645??
When you said map... It is a open streetmap for exemple??? Or only the track ?
But this is a track not the map
