Audiobook/Podcast "...skip to the next track-Button" doesn't work
Hello, everyone,
recently, skipping to the next track does not work in either Audiobook or Podcast mode. Before my problems I used to split my audiobooks into 10min parts which were played without problems by the Garmin 645 one after the other. But now the clock doesn't do that anymore, it just stops the playback after a part is finished. When I try to jump to the next track manually the clock just restarts the current track. Also the 30s back function does whatever it wants (sometimes actually 30s sometimes 30min)
Strangely enough, this only affects the Audiobook and Podcast mode. When I play my music everything works as usual. But since you can't jump back and forth for 30 seconds in normal music mode, which is important for listening to an audiobook, it's only an emergency option to play the audiobook as "music".
Does someone have a similar problem or knows a solution?
I have already reset to the factory settings, but unfortunately it did not help.
Best regards
Fred
  • Yes, I am frustrated trying to play podcasts - I can't skip to the next one and it seems that a the end of the podcast it repeats the podcast instead of playing the next one. I don't see any repeat symbol or shuffle symbol in the podcast mode.
