Does anyone have issues with their barometer and/or temperature sensor? I'm getting no reading from either sensors at all.
Two days ago, my 645M shut down out of nowhere seemingly due to low battery (although I was pretty sure it had 60% just a few hours ago ..). After that, the barometer and temperature sensor stopped reporting any readings -- starting an activity with temperature and elevation data screens showed "--.-" and "-----" respectively, and the temperature widget just showed "---".
I've tried a default settings reset, a data+settings reset, and a master reset (from power off, hold power+start+back, then release start after one beep and back after another). Still no luck.
While trying to reset it, I also stumbled upon Test Mode, and the baro test screen said that the reading was invalid, or something to that effect.
Is that a hardware failure? I hope not, because it's probably going to be a pain in the ass getting a replacement since I've been travelling around quite a bit too.
