Hi,
Since I bought my Garmin Forerunner 645M the weather widget always shows the temperature about 3 or 4 degrees lower than the minimum of the day, in this case 16ºC. I also have an outdoor sensor and the right temperature should be 16 º at this moment, but actually the watch shows 13º C instead of the 16º C.
Also, I would like to know from where does Garmin pulls its weather data, because my smartphone weather app shows 17º, and even that is closer to the right temperature, but the Garmin watch clearly takes the data from somewhere else. Or maybe the Garmin weather is based on the real feel temperature?
I would appreciate any kind of help or recommentation. Hopefully there is a solution.
Thank you. ciq.forums.garmin.com/.../1453655.jpg
