I got the below explanation from DC Rainmaker. I think it might clear this up...
The lowest HR of your day is commonly referred to as your resting heart rate (RHR). Now technically speaking, per most…
Garmin devices that feature an optical heart rate sensor have the ability to calculate a user's resting heart rate (RHR) value on a daily basis. Below is how we determine the value that is displayed for RHR.
RHR: This value is for the current day. It is calculated one of two ways. For users that wear their device while sleeping, the device will read and record the average of all readings while they sleep, excluding periods where any steps were detected or the measured heart rate falls outside reasonable bounds. A minimum of four hours of sleep time is required to register a reading. For users that do not wear their device overnight, RHR is determined as the lowest average reading over a one minute time period during the day.
7-day Average RHR: Some devices will display a 7-day average value which is the daily average resting heart rate over the last seven days. It is a rolling value and does not reset at the beginning of each week.
The lowest HR of your day is commonly referred to as your resting heart rate (RHR). Now technically speaking, per most medical definitions of this, it’s actually your lowest heart rate while awake. Typically you’ll see slightly lower heart rates while sleeping. So the term ‘resting’ is somewhat confusing as some may assume rest = sleep. When in reality, rest = lying on the couch watching TV.
For example, if you confer with the American Heart Association, they note that RHR should be measured while sitting or lying:
“Your resting heart rate is the heart pumping the lowest amount of blood you need because you’re not exercising…Resting, sitting or standing, your pulse is usually the same. Sometimes as you stand for the first 15 to 20 seconds, your pulse may go up a little bit, but after a couple of minutes it should settle down.”
Not sure it really matters. What's important is not the absolute heart rate but the trend, telling you if you're getting fitter. So measuring by preference when asleep is probably because it gives more consistent readings and therefore a more usable trend.
RHR comes from your sleep time. If your heart rate elevates during dreaming and you dream a lot - as I do -then don’t be surprised if the watch shows a RHR higher than you see when you wake up in a morning. It doesn’t matter that much. It’s the trend that is your friend.
