Garmin Connect and Connect IQ Problems after 3.30 Update
Hi all. I’ve noticed a couple issues with both Garmin Connect and the Connect IQ apps since updating to FW 3.30. When using Garmin Connect to configure watch settings like the ordering of applications and app favorites, I’ve found that only changes to the built in apps seem to sync to the watch. If I try to move or favorite any Connect IQ apps the changes are ignored. Also, over the past couple of days I’ve run into issues with various Connect IQ apps and widgets I’ve installed. I’ve found that I can use an app or widget once or twice, but then they all seem to fail to load, instead giving me an image that says IQ with a orange exclamation point. The watch stays in this state until it’s rebooted. Everything was working flawlessly until the 3.30 update hit my watch. Everything else appears to be working fine. Anyone else notice similar issues with their device?
*Update
Turns out that customizing the apps on the watch works through Garmin Express, so I guess I'll chalk this up to some kind of an oddball bluetooth sync issue?
One other oddthing I have noticed recently is that if I use the mobile app and attempt to adjust the settings of a widget or app that's installed on my watch, Garmin Connect will repeatedly kick me out of the app or widget settings section. After about five attempts it will cease kicking me out and I will be able to make the changes I want and save them. It's been doing this even before the 3.30 FW was released. Not sure what all that is about!
    FINALLY someone else has the same problem as me (not 5 times, but sometimes repeatedly 2 - 3 times)!!
    On a Fenix 5 here with the 9.2 firmware, IOS ...
    Nice to know its not just me in a way. Thought I was either going mad or had phone issues!
