Problem with the Weather widget
Hello Garmin’s supports
I want to inform you about a small problem on weather’s widget. The main figure of the widget - Current temperature does not show a correct value. You can see on the picture bellow
As you seen the temperature range is fine 13 to 23 deg C ( 14 to 24 on my iPhone) but the main value is wrong. It is quite clear that 6* isn’t on the range, also you can see the correct value 21*C on my phone. The next thing I want to point out is that on hourly screen
the temperatures are fine. You see that after one hour (8pm) the temperature will change from around 20 to 17*C so 6* there can be no true value.
I hope you will make the necessary adjustments and you will fix this software bug soon
