The run has been logged on my forerunner 35 and appears in the activity logs, but it does not appear on my Garmin Connect and therefore not on Strava or Nike. This is the third time that happens. Can anyone help?
Likely the activity (.fit file) is corrupt. Unfortunately this happens a lot with the Forerunner 35. To see if it is corrupt, try a manual upload to Garmin Connect Web.
How Do I Manually Upload an Activity I Recorded to Garmin Connect?
If you get any message other than Import Complete, then there is a problem with the file. In that case, please attach it to this thread. We can take a look to see if it is repairable.
3 ways to get the file to us:
Thanks for answering, I followed the steps and I got an error when dragging the file, it tells me that it is not compatible.
Was there a problem with this file? I was able to do a manual import into my own Garmin Connect account without any errors.
1 timestamp was out of chronological order
I was able to fix this using Fit File Repair Tool.
Here's the repaired file - 0572.B4P73638-fixed.fit
Download then import into Garmin Connect using the import data page
Some tips to help minimize the occurrence of corrupt fit files:
I am very happy, thank you very much! :)
The same thing happened to me again with two workouts, both are workouts of over 10km
