Forerunner 235, with elevation correction turned off is showing over 800m of elevation gain and 1300m of elevation loss while doing a 6km flat run through central London. 800m elevation gain is the equivalent of a mountain 10kms long and 8% incline! With correction turned on it shows about 20m of elevation gain! Having read other forum questions it seems that the FR235 Altimeter is GPS based so not 100% accurate but also shouldn't be crazy like that stats mentioned above. If it was an internal Altimeter then I would assume it was just faulty. Could you please advise what may be going on? Many thanks
