freezes with notifications, requires hard power cycle, loses current time
After the most recent batch of firmware updates, there have been a couple times when I got a flurry of notifications, after which the watch completely froze with a notification on-screen. The first time it happened, I left it on-screen a solid 10 minutes before holding down the power button 'til it shut down. On restart, the watch had lost its current time setting -- it was something like 13.5 hours off. I left it alone for a couple hours (with "set time automatically" toggled on), but it never updated to current localtime, even persisting through multiple sync cycles with my phone. I set the time manually so I didn't miss my wake-up alarm, went to bed, plugged it in to charge while I was in the shower, and when I got out of the shower, the *manual* time I'd set was wrong. So I toggled "set time automatically" back on and it flipped to current localtime immediately. :confused:
The notification-flurry-freeze thing just happened again a little while ago, so I powered off the watch, powered it back on, and connected it to my PC/Garmin Express, thinking that might trigger a time sync. Nope. So I reset the thing to defaults, thinking there might be a bug caused by my watch face (Actiface) or one of the widgets I use. Nope again: When it reset, it still had the wrong time, even after re-pairing with my phone and syncing with Garmin Express.
As I sit here, it's 3:16pm, but the watch says 5:48 am.
Ain't nobody got time for this, right?
Any ideas for how I can get a stable watch again?
  • You need to get a GPS lock to GE the correct time
    HTH
    CW
  • Not sure why the notification froze the watch, but when you hard reset as you did, the time will always be wrong when you reboot. The time/date is set by GPS ... go outside under sky and start a GPS enabled activity (Run), wait for GPS Ready, and when you go back to the watch face, the time/date should be correct.
    Max
    HTH
    CW
    Max
    Okay, I assumed it was syncing from the phone, but that worked. That's a step closer. Now I just need to sort out whether I'm going to have to turn off notifications. :-/
    I have the same problem after the latest firmware update.
  • Same problem here. Lockup on Notification screen has happened twice in two days. I am new the the FR235. It upgraded to 5.40 the first time I connected so I can't identify if this was a problem prior to 5.40.
  • I have had the same issue in the past fewweeks - probably 6 times or so.
    I started a service ticket with Garmin - hasn't went anywhere...
    But ironically I haven't had a lockup since.... :-) (week or more)
    I couldn't pin point it to an update of firmware, possibly an update to Garmin connect app (droid) and/or a little bit after a droid update to Marshmallow.
    Well, since I'm on iOS, I'm going to say it wasn't an Android update. No way of knowing how similar the codebase is for their Android/iOS apps, but I'm still putting my money on firmware.
    Since I posted this today, I have had two more lockups. When it happens, my Garmin is displaying an email notification; but I don't know how long it was displayed. I have been able to properly dismiss notifications when I catch them quickly after they are displayed. Maybe the problem is related to the length of time the notification is displayed before it is dismissed.
  • Lockups Continue
    Lockup happened two more times for me today. I looked at the watch, saw the email notification message and the watch was locked up. I have had notifications since that and I have been able to dismiss them without lockup. The significant difference may be that I did not immediately respond to the notifications that resulted in a lockup...they may have been there for a long period of time before I looked at my watch and noticed them. The notifications that I have dismissed immediately have successfully disappeared without locking up the watch.
  • Have you tried a hard reset?
    CW
