Optical Heart Rate Monitor not lighting up/switching o
Hi,
I have recently purchased the 235 watch and was looking forward to tracking my heart rate while running.
The heart rate monitor didn't bring/track any results on my first run and noticed none of the green lights were lighting up on the underside of the watch. I have checked the heart rate settings and it's set to auto.
Does anyone have any ideas as the watch is brand new and was working when I first opened it and the green lights were on. It looks like the heart rate monitor is not switched on.
Thanks
  • I guess you have already checked the settings?
    Select Menu > Settings > Heart Rate Monitor > On/Off.
    Did you try to reset it?
    If the device stops responding, you may need to reset it.
    NOTE: Resetting the device may erase your data or settings.
    Hold power button for 15 seconds.
    The device turns off.
    Hold power button for one second to turn on the device.
    copied from User Guide
