Firmware 4.6
I just updated. No explosions so far. ;-) Figured I might as well start off the new thread.
A .3 figure jump... hope it helps people out!
  • Lost Bluetooth
    Ah. But I have lost Bluetooth today. Always worked well before but now just getting nRF51822 instead of my iphone seeing the 235
  • Went for a run tonight with the new firmware and sensor hub installed. Everything seemed fine. Sync to Garmin Connect when I get home and it's a different story
    https://connect.garmin.com/modern/activity/1174445000
    GPS starts going awry around 29:30, and completely fails at 32:31. It still recorded Pace/Distance/Cadence/HR, but nothing on the map. Very strange. Any ideas?
    Updated here as well. Everything looks so good so far! Too bad it's 11 PM now, so I can't try a real test run.
    Although on v2.3 I wasn't getting crashes every few minutes like some have reported here, I was seeing a crash about once every one or two days, so I'm curious to see if this resolves things.
    Good so far, though I wasn't having many problems in the past either.
    Hope to see the VO2 syncing properly.
    Let's see what happens after the next run.
  • Good so far, though I wasn't having many problems in the past either.
    Ah, you're having Vo2 sync issues too? Couldn't find a relevant thread on that one as I've got the same issue. However, with 4.6, it still isn't syncing by the looks of it.
  • I´m upgrading just now. Any new with the RHR issues?
    The release note doesn´t say anything about it.
    Changes made from version 4.30 to 4.60:
    "Improved the reliability of Bluetooth smartphone connections.
    Fixed an issue in which VO2 Max was not being uploaded to Garmin Connect."
  • Vo2 is showing up in the mobile app again for me with the latest updates, and on Garmin Connect web as well.
    It shows Vo2 max from a run that took place AFTER the updates.
    Updated yesterday and just did a run, everything seems fine and I'm glad to see that Vo2max is synching again with GC.
  • Doesn't seem to have resolved the RHR issue. Meh.
    Problem with 4.60, iphone and weather widget
    After update and synchronize with the mobile application (iphone 6), I press the arrows up or down, and exactly when I get to the weather widget, the forerunner 235 restarted... I have reset, and connected to pc and well for a while. But when synchronizing with the mobile app, problem again. It restarts when you get to the weather widget.
    Is there a problem with v4.60, iphone app and weather widget??
    Only happens to me? Or someone else?
