Activities not reflected in Goals
Hi,
I have set-up a goal (started 1st May) in Connect to run 42k in a month.
I can see the goal on the calendar panel, but, despite having completed two runs so far this month (both show as activites), they are not being tracked as part of the goal, which still says I have covered 0% of the target.
Any ideas where I am going wrong?
Thanks,
Westy
  • Hi,
    Thanks,
    Westy
    I don't know if your problem but I am having some like you and its due to wrong watch date setting. My 235 currently shows 20th February but 08th May, so current activities are being tracked on 20th Feb then and not shown in the target and so on.
    I am looking how to fix for right date but no success so far.
  • Show us.
    That would be very hard for us to say, without having seen how you've set up the goal.
    Given that it is possible to create a current/active goal after the period in scope has already commenced, perhaps you should create a new one, take a screenshot while you're at it, and then show us the screenshot if the newly created goal also fails to include your recorded runs in May.
    I created one as an experiment, and my completed runs since 1·May 2016 have been taken into account immediately:
    Thanks...
    I set-up a new goal, using 'Running' rather than 'Street Running' and my runs to date are now showing.
    Thanks for your help.
    Westy
