The default settings allow the device to detect your maximum heart rate and set your heart rate zones as a percentage of your maximum heart rate.
• Verify that your user profile settings are accurate (Setting Up Your User Profile).
• Run often with your compatible heart rate monitor.
• Try a few heart rate training plans, available from your Garmin Connect
• View your heart rate trends and time in zones using your Garmin Connect account.
Has anyone seen their max heart rate be adjusted after using the unit for a while, or should I just adjust it now? I don't have a super reliable estimate for Max HR, but I'm pretty sure it's higher than what is set. If the unit will adjust it, I'll be patient, but I don't want to be waiting for a cat to bark 8-).
thanks!
