Has anyone ever seen the "cadence lock" issue when using an external HR strap? I'm waiting til after Manchester Marathon to return my watch as faulty (I have an RMA but don't want to go without it til after the race) but in the meantime I've stopped using the optical sensor and using the strap. When this happened.
https://connect.garmin.com/modern/activity/1103856131
After my warm up you can see a section with an elevated heart rate, roughly in line ith my Cadence... after a couple of miles it reduces down to the normal level in line with my effort. You can see there is no dramatic drop in pace or elevation that accounts for it - if anything its faster and going more uphill.
I've turned off my optical sensor (In Menu > Settings > Heart Rate Monitor, turned it from Auto to OFF) and the strap was paired OK.
Is it possible there is still some crossover?
