Vibrate when move between HR Zones ?
Hi
Is there an option to make the 235 vibrate once when you move between a HR zone ? Would I have to do it through a Workout ? ie. Run XMiles @ HRzone 3.
Ive seen the option where you get constant alerts when its over or under a certain HR, that is all well and good but seems to be a little battery heavy (may have been tested whilst having 2.5) plus Im not a fan of the constant buzzing.
Appreciate I should do some testing but Im going for a long run tomorrow and it would keep me honest :)
Thanks
Jon
  • Go to activity settings: alerts: heart rate and you can set a low alert and a high alert by heart rate zone. That's about as close as you can get to your request I think
    CW
  • Use custom workouts, now that the missing alerts issue is corrected in firmware v4.10
    Yes, you can create a custom workout in Garmin Connect online for that, and then sync it to your FR235.
