No longer going into do not disturb during sleep times.
Hi all.
Had my watch for about 10 days now. Very happy so far, battery life seems good to me. Will update the various how are you getting on threads once I've done a couple of runs (plantar fasciitis). I took the watch off charge on Monday just before bed and am currently sat on 40% battery left. Not bad.
I'm having a problem now though.
When I got the watch I set my sleep time to be 22:00 to 06:00 every night. Do not disturb mode became active at 22:00 every night and seemed to switch itself off at 06:00 every morning (I'm usually pretty blurry in the morning so not 100% on that).
This morning I had to use the manual do not disturb mode (from the widget) for the first time as I was at the cinema.
This evening my watch did not go into do not disturb mode at 22:00.
This was a great feature as it stopped the move alarm going off during the night etc.
Does anyone know how to restore this functionality? Is there a buried setting somewhere that I have missed?
Running the latest software available through Garmin Connect; 3.30 & 2.50.
Cheers.
    I had the same issue.
    Menu > Settings > Do Not Disturb > Sleep Time
    Toggles do not disturb between off and the sleep hours
    Hi Steve.
    Cheers for your reply.
    That's not fixed it though unfortunately. That's been on the whole time but still no DND.
    I've also tried changing my sleep window and that's not made it activate either.
    This morning it seems to have returned to normal behaviour. I manually turned on DND last night and this morning it has turned itself off.
    I'll keep an eye on it.
    Cheers.
