Help! How do I activate/use a downloaded app?
I've used Garmin Express to download a couple of apps. Garmin Express shows them installed, and I can update settings. However, I can't find them on the watch. I've looked through all of the menus. One of them is simply a watch face, but I can't figure out how to activate it.
I'm sure this is a RTFM question, and I've read/searched everywhere for the answer with no luck. Can someone please let me know what to do?
Thank you!
Steve
    Thank you!
    Steve
    Press the top right start button and scroll through the activities until you see IQ Apps, then enter and scroll if you have more than one. Easy when you know how ;)
    Believe it or not, I still can't find it! I see Run, Run Indoors, Bike, and Other. If I go into Other, I don't see any IQ Apps in there either.
    What am I doing wrong? Thanks so much for your assistance!
    Steve
    Steve
    if you sync with a phone (I have an iphone so not sure about others), go to the GC app, select more, select your device, IQ apps, applications, select the one you have downloaded, and install. Then do the above.
    Got it. I was syncing with my computer. It's Windows Vista, which must be the problem. Everything appeared to work fine, but they never actually made it to the watch.
    I used the Mobile Connect app from my Ipad, downloaded and synced the same apps, and now I see them.
    Thank you so much for the clues which made me try a different download/sync option!!
    Steve
    Steve
    Yes you're right it must have been sync part...actually if you see them in your IQ apps folder under the device they are normally already installed by syncing.
    0 Former Member over 5 years ago in reply to Former Member
    Same here. Everything Synced but looks like garmin need to tweak user experience without being an apple as that would ruin the simplicity
    I couldn't find when searching on connect iq 'trail forks' so found immediately on Google play store on android phone but now cant find how to get in phone
