I've upgraded from the 220 which only had Smart Recording for GPS to the 235 and have turned 1 second recording on.
I was hoping this might give some more accuracy to my running maps when viewed on a computer later, but I can't seem to tell the difference. Both on Garmin Connect and Strava the maps of where I have been continue to show long straight edges around corners, cutting them off entirely (as an example, my local parkrun ends on a 400m athletics track and there is no way I am able to run 20-30 sections of the corners in a second that would produce the long straights on the corners or cut them entirely).
So is the issue that Garmin and Strava still do some "smart" calculations when displaying the map data that results in it looking like this or is it something else? If you can't view the map trail as it was recorded on the device, what is the point of it?
