235 Notification issues
Hi, for the first two days I had the watch everything went smoothly and the notifications worked (Well sort of, I could see that I had a notification, but if it was a text or something it wouldn't let me read it - Note I am using Android with Textra though so I'm not sure if that makes a difference) but then all of a sudden I stopped getting any notification from my phone. I could still connect to my phone and I received the weather, I could still change the music, all that jazz, I just couldn't get any sort of notification to push through to my watch. I tried turning on and off bluetooth on both devices and that didn't do anything, I also checked the privileges for messages in the app and on the watch and notifications are turned on on both. I also did a hard reset by holding the power button for 15 seconds and then turning it back on, and that seemed to wipe it a bit but as soon as it connected back to my phone it re-synced was the same as before, still no notifications. I'm really confused as to what to do now and would appreciate any help :)
Also completely unrelated but I wanted to know what the little bars mean on the left side of the screen on the default watch face. Thanks!
    I can't help w/ the notifications, but if you're referring to the red bars, that's your move bar. The first solid segment is when you're inactive for an hour. Each smaller segments represent an additional 15 up to the 2 hr point. Moving around a bit will reset it.
    Incoming phone calls no vibrate or notification sound
    Hi, did you get your notification issues sorted? I have just purchased a 235 and can get all the notifications except incoming calls. I have a nexus 6 running the latest OS. What if any were your solutions?
  • I have just purchased a 235 and can get all the notifications except incoming calls. I have a nexus 6 running the latest OS.
    Check the Incoming Calls toggle in the Smart Notifications settings, then.
    By the way, if you want others to help, you shouldn't make other guess or look up which version of the Android OS your device may be running. It should be easy enough for you to volunteer the actual version number (which your device's OS settings will tell you) instead of saying “the latest”.
