Newbie questions....I apologize in advance these questions been discussed previously. I have read various pros/cons of GPX vs TCX formats but have still have some lingering questions, so I hope you will bear with me if these have already been beaten into the ground already.
1) Which is the preferred format to use on my Edge 1000 and why? I am a recreational rider and will ride solo most of the time,
2) I am under the impression that GPX files will get you back on course if you deviate from the recommended route but TCX will not do this. Is this true or will TCX-formatted files also get you back on the planned course? Is one format better than the other at doing this?
3) It appears that both GPX and TCX files will give me turn by turn instructions as well as advance notice of upcoming turns. Is this correct?
Thanks....
