I just started using the Edge Explore and so far I like it a lot. I will be using it with multiple bikes and would like to use speed/cadence sensors with two of the bikes. Can I just switch the same sensors between them or should each bicycle have it's own sensors?
You can switch the cadence sensor freely, if you don't find it inconvenient, however the speed sensor poses a problem, because you need to set a wheel size for it. If both your bikes have the same wheel size, then no issue here. Otherwise, you'd have to configure the wheel size on every switch.
dipittenger I think if ypu set the calibration mode to automatic, it will adjust the wheel size for the new bike. If you choose to buy a second sensor, then the new sensor will be in the sensor pool and which ever is activated will be used.
