This problem only started a couple of weeks ago. I can access Garmin Connect just fine, make nav maps and instruct Connect to send files to my Edge 820. I then connect the Edge to my PC via USB, open Garmin Express and note that the 820 is "connected" to Express. Then instruct Express to sync, which it acknowledges and indicates that the Edge has "Recently synced" and that "you're up to date!" When I unplug the Edge from the PC and check to see the newly saved nav-map "Course" files, they are not there. I have deleted and re-installed the Garmin Express program twice, but continue to get the same results. Any suggested fixes would be appreciated.
best,
Ed D.
