This is already at A STIFF HAND-HOLD, and Tap of the Bottom Button. With the arm laid down on a stiff leg.
(the notes are not as if I did the real timing to earlier) I did another simulated ride, on top of folded legs; but I chose to eliminate this ride, because this ride chose itself to add into the ODOMETER. As the previous simulated ride did not. The hilite of this report is these rides WILL ADD DISTANCE, as my folded legs are not moving. The computer does add speed. Add cadence. But the distance is really extreme for non logic add on. THe added speed chooses to go quite high until a certain timeline; then the longer I ride, the lower the speed and average speed get.
But once that Odometer added. That was a big change, what add on.
