Backup paired sensors Edge 520
Is it possible to backup the paired sensors of my Garmin Edge 520 so I could restore them after a hard reset? Restoring the Di2 settings especially would be fantastic, it takes quite some time to enter everything again after the reset,
  • Yes you can
    This is the process for an Edge, but it is very similar for the watches, just some of the folders are named a little differently.
    On the Edge go down in to the Garmin folder and select all the folders and copy them to your PC. Don’t copy the files in the Garmin folder otherwise you will be there all-day copying maps.
    On you PC you have the following folders
    Follow the guide below to decide which files you need and where to place them on the new unit or the original unit after a reset.
    NOTE. If the user has been forced to clear non-vol they may still be able to restore their settings and profiles as the Edge creates a backup of these when it does a software update. These will be as recent as the last update. They are located in the Garmin\Debugging\Backup folder
    Folder Name
    Contains
    Restore contents to this folder on the new unit
    Activities
    Activities
    Activities
    Apps
    Connect IQ apps
    Copy prg files to Apps
    Courses
    Courses
    NewFiles
    HMD
    Screen layouts for HMD
    NewFiles
    Locations
    Saved locations
    NewFiles
    Records
    Personal records
    NewFiles
    Segment_List
    Leader board selection for segments
    NewFiles
    Segments
    Segments
    NewFiles
    Settings
    User profile and sensor pairings
    NewFiles
    Sports
    Screen layouts
    NewFiles
    Summary
    Activity summary from other devices
    NewFiles
    Totals
    Activity totals
    NewFiles
    Workouts
    Workouts
    NewFiles
    Multisport (Watches only)
    Multisport settings
    NewFiles
  • Thanks, I found your answer a minute ago in another thread digging through the forum. Fantastic!
