Cadence Sensor
What is the point of a cadence sensor. Why would i need to know how many times my pedals went round?
  • If you don't want to know, then you don't need it.
    Generally, a cyclist is most effective in certain cadence ranges. A cadence sensor might help you keep within the desired cadence range.
    0 Former Member over 5 years ago in reply to tmk2
    Thank you but it doesn't really answer the question, how is a cyclist most effective between a range , what is the range.
    How do you work out what the range is?
  • This is an individual matter. I think that generally most cyclists are most effective between 90-110 rpm. Pro cyclists usually ride at higher cadence than recreational cyclists. Finding your optimal cadence is not necessarily trivial, and might require multiple rides with a power meter and/or a professional coach supervision.
    If you're not a pro cyclist and do not want to compete on a high level, then I'd stick around 90 rpm.
    Thank you very much, as you have guessed i am not a professional cyclist.
    I will stick to approx 90.
    Thank you for your help.
    I have numerous other questions and i am awaiting a call back from the Garmin help desk.
    All i want to do is download a map and follow it , the download was OK but after that  UGH
    eg
    Garmin keeps stopping
    takes a long time to connect to PC (Windows10)
    Syncing takes for ever then it disconnects me
    I have discovered that if I disable the automatic downloads and disable the WiFi capability, the machine seems to work better.
    It is a very hard bit of kit to set up but I will persevere.
    Many thanks for your advice.
