Map Screen
Hi everybody,
Small problem, since a few weeks when I choice a saved course and start I see my first data screen instead the Map screen that I use to view until now . All my devices 800/810(2) and the 2 820 start with the map, can I select the screen that I want somewhere?
Thank You
  • Under Activity Profiles, you can turn on and off data screens, map screen, etc and customize those screens for an Activity Profile. Then, after starting an activity in a given profile, those screens are viewable by swiping the device screen. This is described in the user's manual.
  • You should also be able to change the 'page' order so the screens open in the order you want when you swipe
  • thank you for the responses
    looigi: I know that I can sweep between the several screens I mean that after I select the route and select ride before it start with the map screen now it start with a data screen
    SUSSAMB: how can I change the page order, I can not found it?
  • OK. I haven't paid attention to which screen first comes up after I start navigating a course so I don't know an answer to your question. It might depend on whether the course you're navigating is a TXC file or a GPX file. Navigating a TCX file seems to include an obligatory training/virtual partner screen and that's what might pop up first. I generally use RideWithGPS to lay out courses and download a GPX to my Garmin to prevent having the VP screen.
  • The 820 does not support the re-ordering of training pages.
  • OK, I do not specially want to re-ordering the pages ,
    I only prefer to see the map screen when I start the calculation off an new trip, and this, like it always was on all the Edge's I own until now
    In fact I don't know when it change and how it come's, I suppose other owners have the same "issue"
    other the same ... or not?
  • Nobody found something about this (smal) issue? Nobody answer me if it is the same on their machine ...
  • I see the data screens first as well, but can't remember this was different for my device in the past.
